Engine/Transmission (1998.5 - 2002) At what pressure do you get
Engine/Transmission (1994 - 1998) Intermittent Power?
Engine/Transmission (1994 - 1998) Exhaust question
starting problems? I just put a higher spring in my new FASS and now at 22 PSI from 15 and a hard start when left a few minutes... ... . thoughts?????We just replaced the old FASS pump with the new Brushless One..... great exchange from the factory.....
22 psi??? Oh I hope your injector pump isn't damaged, according to a guy who just replaced my lift pump, the injector pump can only take 15 psi. Jim Jessup of Diesel Tune Up worked at Cummins for 33 years and retired 6 years ago. He knows these engines better than anyone I have read or talked to.
It seems like some of the pumps stand way over the 13. 5 psi ideal pressure without a problem while others give problems with only a little extra pressure. Who knows why... I had a hard start problem on my truck when warm from too much fuel pressure. I fixed the problem by reducing the pressure to a more normal level. The injection pump ran another 60k miles before it died. Get the pressure down to where it should be and you will probably be fine.
Steve Keim
Aw Jeez... . I just installed the BD pusher on my 98. 5. It raised my fp from 15 psi to 27psi. Am I in trouble? Is there a pressure regulator available for our trucks? Any info will be appreciated!
Thanks in advance,
Dooner
I think Brett from II mentioned that the Bosch test stand standard is 13. 5 + - APPROXIMATELY 3. There is a diaphram that in the earlier days was prone to fail by cracking or failing seals around the edges is too much or too little pressure. I think Bosch has been putting in a stronger diaphram in the newer rebuild kits.
For me, 13. 5 +- as little variance as possible. The bypass valve that comes with the RASP is somewhat settable bypassing everything over xx back to the tank. I know you do not do a RASP, but I would bet that you could order a bypass valve from a RASP vendor. It is VERY well made and large flow ports and easy to take apart and adjust.
Bob Weis
