ATF+4 is synthetic says Chevron
"clatter/cackle" off idle
Question about boost foolers
http://www.chevron.com/prodserv/nafl/auto/content/atf.shtm
I was looking for a quart of ATF+4 for my '03. Unable to find any so I went online. It's a good thing I didn't give in a grab a quart of ATF+3. That would also explain the $7. 00+ a quart for the ATF+4 from the dealership. So according to Chevron, going to synthetic in our '03s is like replacing the air in our tires. It already has synthetic in the transmission.
I asked this to some friends of mine before, but couldn't get a straight answer. None of them knew if it was or not. I noticed originally on the bottle of ATF +4 that it said it was an extended life fluid that would last a lifetime. They didn't come right out and say it was a synthetic, so I wasn't sure.
Yeah, Chrysler switched to ATF+4 in 2001. It is the recommended fluid in all of their autos. DC has even recommended it in their older vehicles as well.
No and according to the Chevron article, it's only available through the dealership. It doesn't have to be Dodge. We have a Chrysler Jeep dealer less than two miles from us that carries everything I need for my truck. I had my last truck's transmission serviced there.
Steve M: I hate to hear that dealship only mess. I checked there first before my first oil change on oil filter's they wanted $16. 00 for their Mopar filter. Geno's sounded a whole lot better at $8. 95
It's only a matter of time before ATF+4 and +5 show up in the stores. ATF+3 is available in Walmart now. I get my filters from Geno's in the kit with four lube filters, two fuel filters and an air filter. I had two lube filters and a fuel filter left over from my '01. 5 kit. They're the same parts with the fluted oil filter being the only difference so I'm using them on my '03. I find it easier to remove the intake snorkel and change the filter from above anyhow.
I had a cooler line failure earlier this summer. I was out in the sticks and wasn't going to find ATF +4. Ended up using Dexron III (synthetic) and added the Lubegard Friction Modifier (one bottle treats 8 quarts if I remember correctly). I've been told by several mechanics that the combination is equivalent to ATF +4.
In fact, the NAPA store that I bought the friction modifier at claimed that all the local shops by the Dexron and modifier for work on D/C transmissions.
In any case, it got me home without any further problems.
Just glancing at the page it looks like there is a disclaimer that it will work for "all" applications "where the manufacturer specifies synthetic".
The Mopar fluid is synthetic, but it is friction modified to work properly. I don't think ATF +4 qualifies.
Just my $. 02
