Engine/Transmission (1998.5 - 2002) Atf+4 tsb 21-010-06
BTMaltby
I had questions about which to use 3 or 4? The discussions seemed slanted toward 3 because it is cheaper. So I thought I would post this TSB which I came across while doing research.
TSB 21-010-06
Automatic Transmission Fluid Usage ATF+4 (Type MS9602)
Visit Geno's Garage
for Truck accessories. Geno's Garage Truck Accessories
Date: April 14, 2006
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 21-004-04, DATED
MARCH 16, 2004, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A
COMPLETE REVISION.
Models: All 89 - 07 Ram Trucks (AD, BR/BE, DR/DH/D1, DC)
1989 - 1995 (AA) Spirit/Acclaim/Lebaron Sedan
1989 - 2003 (AB) Ram Van/Wagon
1989 - 1993 (AC) Dynasty/New Yorker/New Yorker Salon
1989 - 1993 (AD) Ram Truck
1989 - 1994 (AG) Daytona
1989 (AH) Lancer/Lebaron GTS
1989 - 1995 (AJ) Lebaron Coupe/Lebaron Convertible
1989 - 1990 (AK) Aries/Reliant
1989 - 1990 (AL) Horizon/Omni
1989 (AM) Diplomat/Gran Fury/New Yorker fifth Avenue
1989 - 2004 (AN) Dakota
1989 - 1994 (AP) Shadow/Sundance
1990 - 1991 (AQ) Maserati
1990 - 1993 (AY) Imperial/New Yorker Fifth Avenue
1994 - 2003 (BR/BE) Ram Truck
2004 - 2007 (CS) Pacifica
1998 - 2003 (DN) Durango
2002 - 2007 (DR/DH/D1) Ram Truck
2007 (DC) Ram 3500 Cab Chassis
1995 - 2000 (FJ) Sebring/Avenger/Talon
1996 - 2000 (GS) Chrysler Voyager (International Market)
2004 - 2007 (HB) Durango
1995 - 2000 (JA) Cirrus/Stratus/Breeze
2007 (JK) Wrangler
2001- 2006 (JR) Sebring Sedan & Convertible/Stratus Sedan
2007 (JS) Avenger/Sebring
1996 - 2000 (JX) Sebring Convertible
2002 - 2007 (KJ) Liberty
1993 - 2004 (LH) Concorde/Intrepid/Vision/LHS/New Yorker/300M
2005 - 2007 (LX/LE) 300/Magnum/Charger
1996 - 2000 (NS) Town & Country/Caravan/Voyager
1995 - 2005 (PL) Neon
2002 - 2003 (PG) PT Cruiser (International Markets)
2001 - 2007 (PT) PT Cruiser
1997 - 2002 (PR) Prowler
2001 - 2007 (RG) Chrysler Voyager (International Markets)
2001 - 2007 (RS) Town & Country/Caravan/Voyager
1997 - 2006 (TJ) Wrangler
2001 - 2004 (WG) Grand Cherokee (International Markets) Vehicles equipped with Gas engines
1999 - 2004 (WJ) Grand Cherokee
2005 - 2007 (WK/WH) Grand Cherokee
2006 - 2007 (XK/XH) Commander
1989 - 1995 (YJ) Wrangler
1996 - 1998 (ZG) Grand Cherokee (International Markets)
1994 - 1998 (ZJ) Grand Cherokee/Grand Wagoneer
NOTE: This Service Bulletin DOES NOT apply to AW-4 transmissions, Sprinter
transmissions, Crossfire transmissions, MK/PM vehicles equipped with
Continuously Variable Transmission (CVT) and WG vehicles equipped with a
diesel engine (sales code ENF) and a W5J400 or NAG1 transmission (sales
code DGJ).
Discussion:
ATF+4® - (Type 9602) is being used as factory fill for Chrysler Group automatic
transmissions. ATF+4® is recommended for all vehicles equipped with Chrysler
Group automatic transmissions EXCEPT FOR THOSE NOTED ABOVE.
NOTE: ATF+4® must always be used in vehicles that were originally filled with
ATF+4®. DO NOT USE ANY OTHER FLUID.
NOTE: ATF+4® is backward compatible with ATF+3 , ATF+2, and ATF+. Additionally,
ATF+4 can be used to top off vehicles that used ATF+3, ATF+2, or ATF+.
NOTE: If ATF+4® is used to service models originally filled with ATF+3 , ATF+2, and
ATF+ the fluid maintenance schedules listed for that model does not change.
The service interval currently in effect for a given model should continue to
be followed. Refer to the Service or Owners manual for maintenance
schedule directions.
In general terms, If ATF+, ATF+2 or ATF+3 was the recommended fluid, it is now
recommended to use ATF+4.
BENEFITS
Better anti-wear properties
Improved rust/corrosion prevention
Controls oxidation
Eliminates deposits
Controls friction
Retains anti-foaming properties
Superior properties for low temperature operation
FLUID COLOR
Mopar ATF+4® has exceptional durability. However, the red dye used in ATF+4® is not
permanent; as the fluid ages it may become darker or appear brown in color. ATF+4® also
has a unique odor that may change with age. With ATF+4® fluid, color and odor are no
longer indicators of fluid condition and do not necessarily support a fluid change.
Parts Required:
Qty. Part No. Description
AR 05013457AA Fluid, Transmission, ATF+4® (Type 9602), Quart
AR 05013458AA Fluid, Transmission, ATF+4® (Type 9602), Gallon
Policy: Information Only
I would like to thank Bob Bergevin, Arthur Cantrall, Barry Drodge, David Lovell, Bill Maurits, and Steve for supplying the information for these bulletins. And a big thank you goes to Geno's Garage for making DodgeRam.info possible.
Top of Page
DodgeRam.info Home
This page was edited on: May 3, 2004
I would stay on the safe side for both peace of mind and warrant ability, if applicable and use the ATF-4. Can't loose.
I would assume you have a 47RE, posting in the 2nd Gen area????
