As usual I devoured the current issue of TDR which arrived today (#42). I found The Way We Were on page 108 interesting since I am soon to do a transmission filter and fluid change.
On page 108 Tom states "that some manufacturers no tell you not to bother changing the transmission fluid at all".
Which leads me to my silly question, does ATF degrade like motor oil does over time and usage?javascript:smilie('
Another reason for my question is that I recently saw an advertisment for Express Lube (one of the many lube franchises floating around,) In this advertisment they claim a total fluid "exchange", including the fluid in the torque converter.
When I called them, it turns out that they connect one of the transmission lines leading to or from the radiator, then, process the existing fluid through some filtering process four or five times, at which point they hook the transmission line back up and top off what little of the original fluid did not get back into the transmission from their system. They DO NOT open the pan and change the filter. The charge for this process is $79 (for my
Accord - did not ask them about the truck. )
I had never heard of this so I have not used them, however, I am curious what the members thoughts are on this process and if anyone has heard any data on the results.
Tomjavascript:smilie('Oo. ')
