Archived Atf Everywhere!!!!
Archived AC leak, can't find it!!!!
Archived Need Schematic or diagram of 24V
ok so last night after i swapped fuel plates and went for a hard test run, i went over to a friends house. after staying for about an hour we went to leave and i looked at my truck and it looked like there were leaks from every part of my truck underneath. i didn't think much of it because the sprinklers had been on and i thought they had got under my truck.
unfortunately as i drove home ( at 1am) the transmission started shifting really "light" and wouldn't stay in overdrive lockup, i thought ohh there goes my transmission, but then i noticed my trans temp gauge was barely reading 100.
so i barely made it home and this morning i noticed fluid in the dirt under my transmission. so this evening i put some fluid in it to see where it was leaking from, i thought originally it was the front pump seal, but when oil started spraying out of the soft rubber oil cooler line, i figured it out
heres the dilemna, these things are stuck on there BAD!!!! i am using flare nut wrenches, but the harder i turn, the more the hard line wants to snap.
anyone got ideas>????
You may have to cut the fittings out and start over with hose/clamps ot new compression fittings. I doesn't look like you have much room, but a small tubing cutter would be best. A small "tiny tim" plumbers copper saw would work, but you would most likely end up with filings in tubing, ok if you get it all out, but...
Try heating it. Now don't get out the acetylene and a rosebud, but use a propane torch to carefully heat it. You don't want to heat it too much, but enough heat will break it loose.
Chris
