Don,
Here are some specs for the Amsoil ATF you mentioned.
ATF+4 Synthetic fluid is specifically for Chrysler Automatic Transmissions built after 1997. It exceeds the performance specifications for Chrysler ATF+, +2, +3, +4; MS-7176 A, B, C, D & E; MS-9602 A.
Kinematic Visc @100 C. ,cSt7. 5 Requirement 7. 3-7. 8
Pour Point C/F -51/-60 Requirement-40 min.
Brookfield @-40 C, cP 7730 Requirement<10,000
Wayne
amsoilman
94'SLT 4X4 AT/White in color. Factory Tow Hooks & Running Boards. Amsoil By-Pass filter, Amsoil Air cleaner,and all fluids are Amsoil. Optima "Red Top" batteries.
BD exhaust Brake, BD Torque Lock, BD Torque Converter, Dr. Performance Stage II Injection Pump. Mag-Hytec Diff Cover,Mag-Hytec Transmission Pan, Isspro Pyro, Boost,Oil temp Gauges mounted in 3 Gauge post mount. One gauge monitors Engine Oil, Trans, Diff. Temps.
[This message has been edited by amsoilman (edited 01-23-2000). ]
