The mighty Ram has developed an ATF leak between the Automatic Transmission and the Transfer Case. Checked the fluid level of the transfer case..... full. Checked the transmission..... low.
After doing a search through the discussion forums, I am thinking the transmission output shaft seal is bad. Doesn't look like too bad of a job. Drop both drivelines, un-bolt 6 bolts between transmission and transfer case, slide transfer case back off the transmission and replace seal.
Has anyone had some experience with this? Am I going to run into any surprises? Is there an aftermarket seal available?
Comments Please
RK
Comments Please
RK
