Just finished doing a rebuild on son's 96 47RE. Suncoast TC and new Suncoast VB, input shaft and a complete kit. Went quit well for a couple of a amateurs. (the driveway drop without a proper transmission jack was not good) Also replumbed the entire trans cooling system. Threw away Dodges crappy quick disconnect lines (all leaking) and used Aeroquip 322 hose with push on fittings. Also B&M cooler under the bed.
Plan to change the fluid after 1000 miles, check bands, change filter and install the Suncoast Controler. I DON'T want to start a ATF war but need guidance on best fluid to use.
Well, the 'book' says ATF+3 but seems that is becoming unavailable. (found 2 cases after a days search)
The transmission does shift quite hard (the original of course was getting slippy like a Dodge and heating) We had Amsoil ATF in it before the rebuild. I think it is way too hard. Want firm not a sudden jerk.
If we use Amsoil will the shifting be smoother or harder?
Which ATF would smoothest? Am actually considering Tractor Fluid, as I understand it gives good results. Would it be smoother or harder?
The local transmission parts house says the pros put DextronIII in everything. Had cases of it stacked on the floor. Nothing else. He then mumbled something about the 'modifier' but did not elaborate.
So what is the wisdom from you experts? Amsoil? Tractor Fluid? Whale Oil?
