tron1959
I changed the ATF in my G56 about 2 months ago. Only short trips since until last tuesday. We hooked up to our horse trailer which is about 7,000 lbs empty. We had a 400 mile roundtrip. The second half of the trip we were loaded with two horses, so add about 2000 lbs on return.
About halfway there we stopped at a rest area and I noticed for the first time the ATF smell outside of the truck. I crawled under the truck and placed my hand on the transmission. It was hot but I was able to leave my hand on it for several seconds so I was not concerned it was too hot. I also observed no leaks.
We continued on our trip and now the smell was noticeable for the remainder of the trip in the cab. The transmission is not making any unusual noise and shifts just as smooth now as when new. I did notice a few weeks after changing the fluid a faint noise coming from the transmission best described as "shhhhhhhhh". I can hear it backing away from our house. If I press in the clutch and shift to neutral the noise quits while it is still rolling.
I used Valvoline ATF+4 fluid for the refill. This was the first time towing anything since the fluid change.
Has anyone else experienced this smell while using Valvoline or any other brand. I don't know if something is wrong with my transmission or if the fluid just smells much worse than the factory fill.
