Purchase some cheap 2cycle oil or at least motor oil. Cummins in the past has said that you can use up to 5% without problems. Also read the below from Cummins/Fleetguard.
Diesel fuel/lube additive reactions can lead to engine filter plugging problems
Diesel Fuel News, Nov 10, 2003 by Jack Peckham
Pittsburgh -- Cummins and its Fleetguard filter division discovered that a dimer-acid fuel additive used to inhibit corrosion in pipelines can react with typical calcium sulfonate lube detergent additive to form a carboxylic acid salt that plugs fuel filters.
Filter plugging can be very costly to fleets, since it can shut down a truck on the road for many hours. Depending upon driver labor contracts, filter changes may require a special mechanic road-service call, adding hundreds of dollars to fleet costs (beyond the costs of delayed shipments).
If there's a silver lining to this cloud, then it may be that it provides a valuable early warning to refiners, pipelines, terminals and fuel distributors to be careful about choosing additives for current and future diesel fuels, as Cummins consultant Dave Stehouwer explained in a paper to Society of Automotive Engineers powertrain conference here (SAE 2003-01-3139).
The dimer-acid additive problem "may have been an over-treat rate" on a particular pipeline, but such problems could be avoided with smarter additive choices.
On-board used-lube recycling schemes such as "Centinel" dribble a little bit of oil into fuel (<0. 5%) and generally this lube addition improves fuel injector equipment (FIE) lubricity and gives longer fuel-filter life, he said. However, fuels containing dimer acid can react with lube additives in "Centinel" equipped engines, causing filter plugging, Cummins discovered.
--Much Faster Plugging Rate
In one such fleet, filters were plugging every 5,000 miles rather than the typical 25,000 to 30,000 miles filter replacement cycle, he said.
Even engines without oil-recycling systems are at risk.
"As we get closer to ultra-low sulfur diesel, we should remember history," Stehouwer pointed out here, citing the likely boost in lubricity additization. "It's not always possible to keep lubes and fuel separate," especially with the very-high-pressure common rail FIE that's increasingly penetrating the diesel market.
Fortunately, several fuel lubricity additives not employing dimer-acid are available, including ester and mono-acid types (see related story, p6). Dispersant additives also can improve filter life, Cummins found.
Engines with both fuel and oil-lubricated pumps can suffer filter-plugging problems, he said. Fuel-lubricated pumps could rely upon a lubricity additive that--if not carefully selected--could cause fuel/lube additive interaction problems.
Reducing the level of sulfated ash in future lube oils also could reduce the rate of plugging caused by acid/base interactions, he added.
