ATS COMMANDER/ Negative
New 6spd or Auto
Edge Juice I just called them
I have had three commanders and three wiring harness,The first wiring harness fried two units because the ground wire was pin in the hot wire slot and the hot wire was pin in the ground wire slot,Than was sent the correct wire harness the pin connectors are very lose in their slots which cause a intermittent problems. With the last trip to Colorado {FOR SNOWMOBILING, POWDER WAS FOUR FEET DEEP,AWESOME RIDING,Did not have time to stop by ATS} I had to place tooth picks in the slots to stop the problems. When I return home I had the new harness that ATS sent REPINED. Now it works great,If you need to remove or move your commander be careful for the harness is fragile.
I have made my concerns to ATS , I also think they are working on a fix and hope they will send me a updated pin connector in the future. The transmission is awesome and would recommend it to anyone.
I installed the Commander in my truck this morning. I went for a drive and the trans acted the same as before the Commander. It never sends the signal to lock or hold the converter. A couple of times the Tow Haul light came on when I started the truck but most times it does not. Changing the set points makes no difference. All the wireing connections I made appear to be good. Anyone have any ideas?
