Ok, so I was assembliing my ATS manifold last night and had some issues. I had the two outer pieces in the freezer for the past couple of days and had put the center piece in the oven for about 20 minutes. But the middle piece was only in the oven at 250* F which I found out was not hot enough to make the installation easy.
So, tried one side first after I pulled the middle out of the oven and one piece out of the freezer. Coated the ends in some good anti-sieze and went ahead and hammered it in there with my rubber mallet. Well, it didn't go in very easy like I thought it would, but I got it in about 3/4 of the way with some serious hammering.
Before I put the other piece on, I stuck the whole assembly back in the oven @400* F for 30 minutes. This time it really went together easy!
Just a couple of good hard hits with the mallet and it was in there. Also was able to hammer the other end that didn't go in so easy.
So, here in my question. I wasn't able to get the end piece flanges to line up with the middle piece flanges. I had the manifold on flat ground, but after hammering for about 10 minutes I still could not get the flanges to be flat and straight with each other. So, for a solution to getting the flanges straight I was thinking about bolting it up to the stock manifold flanges when I removed it and putting 12 bolts through the holes and tightening until the ATS is flat with the stocker? How does that sound or is it a bad idea?
I was thinking about trying it on the head when bolting it up but I didn't want to crack an ear on the head from torqueing it down to get it flat with the head flanges.
Sorry for the long explaination, but just wanted to fill you guys in on this. Thanks in advance for your experienced advice!
Joe
Joe
