I modified the horizontal L-bracket as follows: I shortened the short leg of the L (which is parallel to the centerline of the valve cover), removing enough material with a die grinder to just remove the OE attachment hole; I then relieved approx. 1/4" along the underside of most of the long leg of the L and all of the short side for adequate clearance between the manifold 3-4/5-6 joint, redrilling a new attachment hole in the short leg of the L at a somewhat centered location (centered front to back, off center in relation to height... up and down). Afterwards, I fabricated a trick aluminum, gusseted L-bracket that attaches to the recently modified steel heater hose L-bracket and to the raised mounting boss on the ATS manifold (there is only one raised mounting boss). This functions very well and looks extremely trick. I don't remember what size the threaded hole in the raised boss is however, I do know it's Metric.
This is one of those projects where all parts are not included. What the he!!, it builds character.
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP braided s/s fuel hoses, Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
NRA Life (Patron) member
