ATS Manifolds give lower EGT's??
Fuel pressure gauge install
Amsoil for the rear end question.
Did a search on ATS manifolds but did not see anything said about lower EGT's. Anyone running ATS manifolds, did the install of one lower your EGT's?? Especially like to hear from people that may have one on a ETH.
Thanks for any info!
Merry Christmas.
Mike
[This message has been edited by Mike Vonada (edited 12-25-2000). ]
the only thing that manifold will do is keep fom loosening the exhaust bolts it will move as it heats all the big engines run them thay are worth having though IMO as for egts I doubt it on the eth because the eth man already uses "the header effect" in it
In most cases the exhaust turbine housing is the biggest restriction = higher egt. If you don't bring those egt's down, eventually the head will crack enough for automatic water injection from the cooling sytem #ad
