Hey Bob,
I found out that an easy way to assemble this manifold is to freeze the two outer portions of the assembly overnight and when you get ready to piece it together heat the inner piece up with a propane torch slightly where it joins in the knuckle.
It does not take alot of heat with the outer portions frozen and the inner piece expanded from the heat. Slop on a bunch of never-seeze on the joints before you pop them together.
I did not even need a rubber hammer. They just slid together easily. After assembly you can lay it on a flat bench and pound away on it with a rubber mallet to get a good flat mounting alignment.
You have to work fast, as soon as the metal cools on the inner piece, it shrinks back fast.
That never-seeze is nasty stuff, it gets everywhere and is tough to get off surfaces.
You are gonna laugh at the factory manifold after you compare it to the ATS piece. Worlds apart! This thing is a good quality piece and I got it at a killer price to boot.
I like the stud idea myself. I was going to do it as well, but since I am replacing the cylinder head with a Donnelly ported jewel I decided to do it at that time I swap the head.
Don~
