ATS trans and Lockup Commander install
Power Steering Pump died 9-17-05
time for new tires
WCPoe
I'm having the ATS trans/converter/Commander installed on my 2004. 5 2WD this friday. The trans/converter install should go fine, however, I may end up doing the Lockup Commander install myself due to time constraints. Obviously the RED hooks to power and BLACK to ground. Can anyone verify the wire colors going to the 48RE 2004. 5 model that get cut for the lockup control and the speed sensor tap.
The instruction diagram shows to cut a yellow/lightblue from the PCM to the trans, but I don't think that matches what I see in the 2004 CD based manual.
The instructions also say to T-tap a darkgreen/yellow for the speed sensor, I believe the 2004 CD version manual shows a darkgreen/ brown?????
Thanks for any knowledge you can share.
I would think your manual is for the older, 305/555 engine and PCM, and the colors may well have changed on the next motor. Do you have the requested colors in you PCM wiring harness? If you do I would say try ATS and double check with them if no one pops in with an 04. 5 compatable wiring diagram. Good luck.
