ATS WaterBoy installation
Dr. Performance Sold !!!
What will happen if i disconnect my wastegate actuator?
Can anyone tell me where they have installed the electronic box and the water splitter/relay box in a 2005 Ram?
The Edge box is located where they suggested, on the fuse box. Other than that are the ATS twins and ATS intake manifold that may help decide locations.
Waterboy location
I am kinda surprised no one has responded... I suppose there just aren't many of these units out there.
Anyway I finally figured where to locate the 2 boxes. On the inside of the drivers side wheel well cover! Simple as that. I haven't done this as of this writing. I belive it'll be easier if I remove the wheel well cover and then mount the boxes. The only thing I am concerned about will be the accessability of the electronics box to do any readjusting of the EGT setting for each of the 3 nozzles. I'll probably have to do this from under the vehicle. Those adjustments use a jewlers screw driver. Arrrg!!!:(
