I sent this is a PM to you, but with the server problems, I don't think you received it. I decided that this may have application to the general membership so I am posting the contents of the original PM as a topic.
---begin posting---
Gary-KJ6Q
I have read with great interest how your ETH seems to run very cool (<1200F always) when towing, even when running at the 5X5 setting on your Edge Comp. I'm currently searching for ways to keep the EGT's in check on my own ETH when towing hard, uphill--and I'm only towing 5-6K lbs.
While considering your apparent good fortune, the following thought has been nagging at me and I wanted to share it with you in hopes that I might prevent you from seriously damaging your rig.
In a nutshell, I think your thermocouple is lying to you. Sometimes a thermocouple will reach a "maximum" value and then stop producing a proportional voltage, regardless of what the actual temperature is. Outside of a complete failure to produce voltage, this is the most common symptom of thermocouple failure.
You can easily check your thermocouple by removing it and heating it with a simple propane torch while it is hooked up to a digital voltmeter (or the pyro gauge itself). Be careful not to get it so hot that you ruin it (assuming nothing is wrong with it to begin with) but heat it enough to verify whether or not it "stops" at a certain voltage value and won't climb any higher, regardless of how much extra heat you apply.
Good luck and I hope you find your thermocouple is in working condition.
---begin posting---
Gary-KJ6Q
