Atwood Water Heater
$1.4+ Million Motor Home
Looked at the Raptor Toybox
I just purchased a Atwood water heater to replace the one in RV, it has a blue wire, a brown wire, and green wire to hook up. The green is ground, the blue comes from the board, and the brown comes from a sensor on the water tank. I think the blue goes to switched 12 volt, what is the brown wire hooked to????????
hope this helps
Ok you shoud have a remote switch. It has a toggle and a light next to it. Blue goes to pos #6
Green goes to pos # 4
Brown goes to pos #3
a wire then should go from pos # 2 to the positive side of the battery.
Manganos,
Thanks, I went to the Atwood site, the pdf files for schematics would not work, I purchase the heater used, I have a switch, I guess the Brown provides 12 volt and the blue goes through the light to ground, have you got a schematic???
email -- email address removed --
Thanks///73
send me your addy
KB0OU said:
Manganos,
Thanks///73
I do have the schematic but no scanner. I could copy them and send it to you if you send me your address. -- email address removed -- will get it to me!
