Originally posted by Badunit
I don't have my truck yet so I'm quoting from the service manual here. With the EVIC overhead console (the fancy one), there are several user programmable choices for the door locks. Yes/no to automatic door locks. Yes/no to unlock on exit (the option you are asking about). Remote unlock driver door first/all doors. Yes/no to flash lights with locks. Yes/no to sound horn with locks.
The unlock on exit feature unlocks the other doors when the driver door is opened and the vehicle is stopped and in park or neutral.
With the EVIC it says that when you select Yes for automatic door locks you are then presented with the second choice of unlock on exit. Without the EVIC the manual says you need to use a DRB III to program the automatic lock feature. It doesn't mention the unlock on exit feature but that's probably an oversight.
Is there is a procedure to program the automatic locks with the transmitter? If so, it isn't mentioned in the service manual.
Originally posted by Parshal
in having the doors unlock when turn off the truck. Unfortunately, there's no way to do that.
Thanks again!
Originally posted by Jeremiah
The easy way to do that is to hit the unlock button twice after you turn off the truck![]()
Originally posted by lschultz
I had my daughter try like it says in the manual and it still don't work. We can not get the ding from computer like it is suppose to. Might have to take it to dealer and get them to hook up there big puter and do it.
That's the problem, I don't want to have to do that every time I shut off the truck and get out. It seems I always remember that AFTER I've walked around to the drivers side to get something.
I agree, it is a pain in the butt. It'll take some getting use to. It's like those automatic door locks at 15 mph. I don't like 'em, but I'll get use to 'em.
I was able to disable that automatic door lock following the owner's manual. It did take six tries though.
Does anyone know of a way to disconnect the automatic door locks? Or, better yet, a way to have the doors unlock when the truck is turned off. It's beyond annoying to attempt to get into the back doors or passenger door and have walk back around the truck to unlock them.
