2nd Gen Non-Engine/Transmission Auto down drivers window
Want the same function on the other side. How to do? If it can be done can it be controlled from the drivers side only?
Joe, there was a post on this a year or so ago. I would like to do it to, but did not bookmark it. Try a search on "express down", I am getting older every day but that is what I remember the term for that function being. Hope this helps, and hope all is well with you and yours, been a while since I heard from you. Take care, Howard.
The Auto Down feature is controlled by a electronic circuit inside the Left switch. I have no other info on it other then the service manual says if the Auto Down feature doesn't work and the window goes up and down - replace the switch. You may be able to buy a Left switch and hack,chop, modify it to make the Left switch work on the Right door, or maybe it'll be a waste of time and money.
HTH
Wayne
