auto down pass window
Natural Beige for A pillar mount- discontinued?
I didn't know it was one piece...
Did a little searching and didnt come up with much, found someone ask about it but no really any answers that I could see. So my Question, is it posable to get the passanger window to auto roll down with just one push on the button like the drivers side does? I would think that all it would take would get a switch just like the drivers side window switch and wire it in place of the old one but I have been know to be worng and I havent see any wireing diagrams yet so I dont kow if all 4 switches are 1 peace or not. Anyone have any input?
Thanks
Justin<><
Since the Almighty PCM Controls Everything you'd probably have to hire Bill Gates to reprogram it for you to recognize the switch signature and respond by fully rolling down the passenger window :rolleyes:
But it is a diffrent switch too. The auto down switch has the initial position that allows partial downward movement followed by auto down when you reach the end of switch travel.
-Scott
The driver's switch has a current sensor in it that heats up as the motor stalls as the bottom of travel. The switch locks in the down position and trips to the off position when the current sensor heats up. Similar to a circuit breaker. It would work on any window but buying a switch to fit would be the challenge. I don't think you can buy individual switches.
Casey
Casey
I'd try to locate the company that makes the switches for Dodge. Maybe there's a manufacturer/part no. on the switch itself?
What about our friends down under???? Doed dodge make a right hand drive truck???? If so the switch might be more avabial then you think. Only problem is the local deealer???
Now that's clever!:cool:
