Engine/Transmission (1998.5 - 2002) Auto fluid capacity
2nd Gen Non-Engine/Transmission speedo broken/abs light on
2nd Gen Non-Engine/Transmission Carpet from an 01 to a 97?
Fluid
I believe it's 7. 5 Qts if your just dumping the pan with filter change, or like 15. 5 if you drain the TC as well. You'll only be able to drain the TC if you have an aftermarket TC with the drain plug. I've read that you can carefully loosen the VB & drain some of the fluid out of the TC though but I've never done it.....
Clay
