Auto meter gauges
Advice On Mufflers
Lift Pump and FP
Hi Everyone and Thanks in advance; I am looking to install a boost and egt gauges tomorrow in the new dash pod. Haven't figured out the 3rd gauge yet. . 6-speed... I am probably going to run wiring and tubes along windscreen down over to drivers side of dash for now, prior to drilling a hole in dash. My question... connections for light circuit ? At the fuse panel maybe or somewhere else ? Also, any ideas about the 3rd gauge.
I am looking to set some baselines for the engine prior to bombing and pulling new 12,000 lb dump trailer.
2001 4x4 quad 8 ft, eth, trailer, camper, leather(even with covers here in fla, seats a bit hot) Patriot Blue-love that color. . still stock,
13,100 miles. . now getting 17. 25 mpg around town no trailer yet,
Wildcat Flash- real running boards stainless and dalmation dog hair between seats... priceless
Fuel Pressure
I decided on fuel pressure for my third gauge. As much as I read here about defective lift pumps, I opted for the peace of mind.
Ethdee
my vote is also for a fuel pressure gauge. Littlefuse makes a Add-A-Circuit model# FHM200 it will fit is the fuse panel on the side of the dash. use the #5 circuit, which is the illumination for the dash lights. it will give you the ability to dim the gauges.
Fuel Pressure Gauge
I would go with the fuel press. gauge, it would be nice to know what the little lift pump is doing!:rolleyes:
Gauge lighting power source
I tapped into the instrument lighting rheostat
that is part of the headlight/interior light
switch. The dash overlay needs to be removed
to gain access to the switch assembly. The black
overlay just snaps in. Carefully pull out with
your fingers around the edges till all the tabs
are pulled out. The part I am talking about is
the black plastic overlay that surrounds all the
gauges, radio, AC/Heat controls etc. When it is
removed, then there are three screws that hold
the light switch in. Remove them and pull out on
the assembly and look for the tan wire. Use a wire
tap and connect your positive wire for the gauge
lighting here. Find a suitable place on the metal
frame of the dash somewhere under the steering
column area for the ground wire. The square kick
panel under the steering column comes off to
expose a couple of good places for the ground
wire.
This way your gauge lights will dim when you dim
you instrument lights.
-Chris
