auto trans clutch material
Isspro EV Style Fuel Pressure Guage?
twins with ball bearing turbos?
Just wondering if any body knows what types of clutch fibers that DTT and ATS use in there transmissions used for light towing or daily use . Alto red or blue ,Borg Warner , Kolene steal plates are just some of the choices . They may mix and match based off of need , just wanting to know if anybody is in the know? Who is the closest approved builder to Alabama?
_______________________________
2000 QC LB 4X4 AUTO 3. 54 Rips Exhaust, Lightforce 140, Husky Liners, Rhino Liner
I would call them and ask on the clutch material.
I went the xxx route (see sig) and call and they will gladly tell you where the closest installer is.
I read a post about a day or so ago that the TDR member had a local transmission shop do the install with approval from DTT.
I did not think of that when I got mine done and drove quite a ways to get to the installers shop.
Bob Weis
ATS uses a really amazing clutch material made by Raybestos. MUCH better than stock.
I am familiar with the stock lining, which will burn, degrade, peel, bubble, crumble etc. under high H. P. & Torque. The ATS Raybestos linings will NOT burn, I tried to light one up with a lighter when I was at ATS getting my trans done! They won't peel or degrade either. This is another reason why I say that ATS does the most thorough job of engineering of any of the Performance Trans builders.
