I have a 97 Ram 4X4 3500 with 80K miles and an Automatic transmission. My problem is the trans does not want to down shift when I slow down. This problem is most apparent when slowing enough to require 1st gear. The truck must come to near a complete stop before it will drop down to 1st. I read in the maintenance manual there is a (Front Kickdown Band) adjustment. The manual states to tighten it to 75 Inch pounds and then back it out 2 7/8 turns. When I spoke with my local service center, they said it was normal. The truck does this to allow the trubo time to spool up before putting a load on it. I thought that was the hole benefit of the monster torque from the cummins. Is this true, If so am I doomed to driving my Auto truck from the column forcing it to shift down. P. S. This is my first post. I am a new member!
Jeff Brosseau. 97 3500 4X4. Auto Trans
