Engine/Transmission (1998.5 - 2002) auto trans fluid
2nd Gen Non-Engine/Transmission WTH, kinda ****** off
Engine/Transmission (1994 - 1998) 191's are in, 370 stumble is OUT!
hey guys, I should be getting my mag-hytec deep pan in a couple day,it is time for oil change on trans,got a question on oil. I been using valvoline dexron/mercon 3 (max)the last two oil changes, got it from local napa dealer. called napa today to get a case of oil for when trans pan gets here, they said i could also use valvoline +4 full syntetic oil, they said it was and upgraded oil for d/c trans. what do you guys suggest on valvoline +4 oil full syntetic. thanks for any info that you can give.
If you can get it at a reasonable price, it is actually what is recommended for your trans. However, it is IMPOSSIBLE to get here in Mexico. I have run Dexron III for over 100k miles with no problems.
Steve Keim
