Details here: TDR Privileges
Like most things, you have to use your head. A little power brake will warm the fluid, a lot will burn it along with the potential to burn parts as well. I do not see 1,000 RPM power brake for 30 seconds at a stop doing any damage, but it should only take a couple of stops to warm the fluid up some.
If I’m not mistaken the trans oil always flows through the coolant/trans oil heat exchanger on the side of the block. That means the trans fluid will suck heat out of the coolant until the trans warms up which will make the engine take that much longer to warm up. By bringing the rpms up the engine heats up more and the shearing of the trans fluid in the converter heats the trans oil so everything heats up faster. I have a trans temp gauge in the hot line and only bring the rpms up at the first few stop lights when the trans temp is below 100F. Does it make a huge difference, I don’t know, but as long as it is not hurting anything …. .
The new 1500 with Stop Start uses a trans fluid heating system to heat the fluid on a cold start. You guessed it, there for fuel economy improvement. Warm fluid, less friction.
