I installed a Mag Hytek pan on my trani a few days ago. Changed the filter and pan fluid. Everything went fine, except for the fluid bath I got when I pulled the old pan off.
Drove the truck around the block and the shifts seemed a little more crisp than usual. I checked the fluid level and found that I had about 1 quart more than I should have in it so I drained about a quart out. It is still slightly past the max mark on the dip stick.
Drove the truck for a few miles and the trani seemed to shift okay, everything normal. Today, two days later it seems that the shifts are kind of mushy and something seems different from the way it ran before.
The fluid and filter were changed awhile back by a shop and I noticed when they pulled the filter off that there was a lot of metallic dust stuck to it. When I changed it this time I didn't see any metallic dust on the filter or even at the magnet in the pan.
I can't tell if it's my imagination or if it's really not shifting the same as before. It's not slipping.
My question is: Would it be possible that the shop that changed the fluid the first time used something other than ATF 3 + and maybe it's not compatible with what I put in? I assume that is what they used cause they didn't drain it all the way either.
My only other thought is that it is just a coincidence that it's starting to go out right when I changed the fluid. Maybe I stressed it out with the extra quart in there?
Sorry about the long winded post. Thanks for any suggestions.
