I have a 1998. 5 24 valve with automatic trans and tow an enclosed car trailer with a gvw of about 8,000 pounds. I have always been told not to tow in overdrive as this will fry the trans. After installing the trans temp gauge, I towed in overdrive on the highway (60 to 65 mph, outside temp in the 80's) and the trans temp stays around 150. My sending unit is mounted in that line from the trans to the cooler. Is towing at this temp a problem or is it somthing else that will trash the trans if I tow in overdrive? Any replys will be very helpful. Thanks
