Cruising around today, doing about 75MPH, then let off the throttle while coasting down a hill... part way down the hill, my transmission locks up (as in chirps the rear tires
), then drops to 3rd gear, no TC lockup, and been there ever since. I was 20 miles from nowhere, so I had to limp it to the nearest town.
So far, here is what I found:
Truck feels like it's dragging when taking off. . like it's in 2 gears
transmission is full of fluid, fluid is clean and smells ok.
Got a code P0753 -- 3 / 4 shift solenoid / Relay circuit
Truck currently has NO O/D or TCC lockup
Can press O/D off button, but no RPM change, no lockup. 3000 RPMs @ 60MPH
So, where is the 3/4 shift relay? Solenoid? Could this cause it to hang in two gears at once? I need help guys... I'm stuck.
