Hey guys, I tried searching the archives for answers, but figured it would be best just to ask.
I want to change the transmission fluid in my '92 W350 automatic tomorrow, and replace it with Amsoil. Will 12 quarts be enough to do the job including the torque converter?
Also, after dropping the pan, changing the filter, replacing the pan and refilling with new fluid, I want to flush the old fluid out of the TC. Which transmission cooler line should I remove and route to a bucket in order to do this? I only flush one quart at a time to avoid running the pan dry.
Thanks in advance!
- Mike
Thanks in advance!
- Mike
