Trans temps
I regularly see 190 degrees running solo in stop-n-go when ambient is in the 90's—but it should drop off pretty quick when you're rolling again (140-150). From what I understand the first thing to go with heat (and thus decomposing ATF) are the friction faces of the servos: the clutch packs and the bands. I've though about adding an auxiliary fan for the AT coils since the OEM cooler sits kinda out of the main airstream. Food for thought…
