Automatic Headlamps 2007 Dodge Ram 3500?
Is it time for PM & replace orig working Pwr Steering unit?
Driver Door lock won't work?
Is it possible to pull an automaticheadlamp switch and sun load sensor from a 2005+ Dodge Dakota and install it into my 2007 Dodge Ram 3500? I know the switch is an exact fit and the wire pin out is the same but I don’t know if the sun load sensor can be used in conjunction to make the system a working automatic headlight system. I am wondering and hoping that it may be an easy upgrade like adding fog lights with the preexisting wiring.
I know that there is always the option of installing the 545T Nite-Lite aftermarket automatic headlight system, but I would rather use the factory switch with the “A” setting.
I know that a lot of people don’t care about automatic headlamps but I would like to have them. Has anyone else done this or know if it will work or not?
I’ll be following this, I would like to have it in my 06 2500 diesel MegaCab. I seem to recall reading somewhere you could add the headlight switch and light sensor from a Dakota and make the auto headlights work. If that’s all there is to it, I can’t find the info again.
