If I understand correctly the pressure that locke up the torque convertor (on the stock transmission) is determined by the throtle position. If this is true then when one bombs the truck and it requires less push on the accelerator then you have less pressures in the transmission. It looks like more power from bombing with less pressure on lockup would be a bad situation. Is my reasoning correct or am I completely wrong here?
Thanks
Ken
Thanks
Ken
