Condition is no go in reverse or forward, acts like neutral, but slightly surges forward when throttle is applied in low. Here are my pressure readings:
Manual low: Accumulator port 88psi rear servo 90psi @1000rpm
second:accum 88psi @1000
drive:accum:88psi@1600 front servo:90psi
reverse:rear servo 260psi @1600
overdrive: accum 110psi and od 106psi @1600
The transmission is strong in 2nd drive drive and overdrive, at least on jackstands. I can pull the engine down with the brakes in drive on stands. To get it to shift in second, it must be on stands and run through first.
I pulled the valve body to do an air test and found everything strong. According to the chart, in reverse, the front clutch rear band and direct clutch are applied. Ruleing out the front and direct clutch because they are strong in 3rd, it leaves the band. In low the overrunning clutch should be holding first, plus it is holding in second. I overlooking something, but what? Could a valve be stuck?
