I just had my automatic transmission rebuilt and everything is good except for the shifting from 1st to 2nd and 2nd to 3rd , each of these gear shift points hangs. The 3rd to 4th is fine as well as lockup. This problem happens when you drive normally. If I take off hard (WOT) it will shift fine. If I take off slow it will just hang in 1st until I either kick the peddle to the floor or let off the peddle momentary. I have to do this in 2nd gear as well. My transmission guys have tried to fix this. It will work for about 10 min and then back to the won’t shift unless you are WOT or kicking the peddle to get it to shift. I drove it all weekend and a couple of times it started working correctly on it’s own. But that only lasted for a few minutes. The transmission guys swapped out the brand new solenoids, because they claim that they have found about a 25% failure rate of brand new solenoids. Just to give everyone a idea of what I have in this transmission I will list it below. Does anyone have an idea on what might be going on?
· New Multidisk billeted torque converter from Midwest Converters. http://www.raceconverters.com/iCONT.htm
· TransGo Shift Kit
· Raybestos Blue Line racing clutches.
· New 3rd gear hub that holds 6 clutches
· 4th gear hub now has 23 disks
· New 6 pinion 1st and reverse planetary
· New 2nd gear ratio lever 5:1
· New upgraded servo covers
Chris Brandt
Alaska
· TransGo Shift Kit
Chris Brandt
Alaska
