My 2000 Quad cab, Auto 4X4, with 100K miles was hunting around 3rd to 4th, lock and unlock the TC, at about 40-45 MPH. Today I did the preliminary steps, Disconnected and cleaned both Batteries, Cleaned the grounds on the Fenders, Cleaned the ground strap from the PCM to the Cowl. The connection at he PCM was terrible! The PCM has an aluminum chassis, and it was corroded were the ground strap was connected, and the other end was just grounded though the threads of the self-tapping screw. I cleaned up both ends with a Scotch -Brite pad in a 90 degree sander and reconnected. After reconnecting both Batteries, I did the APS re-set thing. Now the truck drives much better, for now. I am not sure how long this fix is going to work, but I’ll wait and see. If this comes back I’ll have to do the DTT Filter. Regards, Moose
One Week later, and it's still working Good
