Automatic transmission
Leaning Truck Survey
BFG AT KO's 315/75R/16's & Fender Flares
satmike
Can anyone out there give me an idea on what the service life of my auto. transmission should be? I have 160k miles and am wondering if I should start thinking of a new one? I spend 4 months in Mexico each year and would rather not lose it there.
Thanks Mike
92W250,auto,3. 54,16cm2,JRE injectors,borgeson joint,3 1/2 dynomax race magnum ex. ,addco sway bars,seatco seat,peeling white & silver,K&N filter, Isspro boost&pyro
I asked the same question a couple of weeks back - the concensus seems to be that you are at about the point where the *average* A/T could use a rebuild - many go fewer miles before overhaul, some go further... Like you, *I* prefer to have mine taken care of at a time and place of MY choosing rather than "Murphy's"... #ad
http://community. webshots.com/user/davison71 Early '91 250, 727 AT, 307 rear... Banks Stinger exhaust, intercooler... US Gear OD... Tweaked pump, upgraded radiator... MORE than a match for every new PS Ford encountered so far...
"Dura" WHAT? NOW I know where all those recycled beer cans go...
My 92 service truck went 135 before I overhauled it. It runs at 8500 lbs in stop and go traffic. I have pulled campers to CO a few years. It had shifted so many times, it had worn the seperator plate almost in two in several places. It was hanging on to shifts too long. I decided to do it before it went at a bad time.
Mark Faught, 92 ext cab service truck and a 84 crew cab one ton dually with a 91 cummins and NV 4500.
Thanks I've been out of town for 4 months,so i'm a little behind on the past threads. sorry to repeat questions,but it sounds like I should start looking at the new transmission options.
Thanks again Mike
My 92 has 200,000 miles. All its had done to it is regular maintenance(fluid,fliter,and band adjustments).
Gene
92 350 4x4
Well, my '93 has 153,000 and is on the third transmission. All of those were BEFORE bombing so I'm not sure how long this one will last!
Stan
93 2WD extended cab, Banks Power Pack, K&N air filter, PW Injectors,rebuilt and tweaked pump, auto w/3. 54 rear with limited slip, US Gear Exhaust Brake, 3-1/2" Exhaust, 5K air bags, Boost/Pyro/Tach Gauges, Green/Silver, new 40-20-40 bucket seats, 151K
168,000 miles with moderate towing and still shifts very nicely. The previous owner was a little lax on transmission maintenance, but everything works fine. I am going to adjust the bands this time when I change the oil and filter. I know of one 1992 with a 240,000 miles that has hauled four to six draft horses all of its life and it has never had transmission problems. Hope this helps you out a bit.
Jeremy Sweeten 1992 Dodge W-250 4x4 Cummins Diesel, Intercooled,LE Package, 166K, AT, Warner Hubs, Dana 60HD 4,060 lb. front axle and Dana 70 6,084 lb. limited slip rear axle with 3. 54 gears, NPG 205 transfer case, 3. 5" Banks exhaust straight pipe, K&N air filter. Tekonsha Voyager XP electric brake controller. Una-Goose 30,000 lb. gooseneck hitch.
http://home.earthlink.net/~sweeten1/index.htm
