Years ago I read an article in the TDR about a guy who had an electric fuel pump that he used to fill up his aux tank. He would fill the stock tank and then pump it up to the aux tank which was under a canopy and then pump it back down when he needed it. It was a 2 way pump. At that time I had a long box with a canopy and had just bought a 75 gal aux fuel tank for it. I changed the side window in my canopy to a windoor and filled up the tank that way. Much simpler. I used this set up on my last 2 trucks but now I have a a short box and can't get a windoor for this canopy.
How do I fill up the tank? There is No room to add a fuel door to the side of the canopy because the window is so large. I am Not removing the canopy for my trips. I can't make a long filler pipe to the back of the truck as it would be too high and could easily over flow the tank. When I stick the nozzle in the tank and it kicks off that means it is Full. Getting the fuel out of the tank is no problem as it can gravity feed to the stock tank like I have done before. Because I have a short box I thought of Not mounting the tank permanently because I only need it for the summer and because it is a short box.
One suggestion was to mount the tank front to back on the RH side of the box ( helps balance the weight of the stock tank on the left ) with the filler neck at the tailgate end and to use a 12 pump and a long hose with a nozzles and fill the stock tank thru the fuel door.
Anyone got any good ideas ?
David
David
