HBarlow,
The tank is a RDS, 100 Gallon, in good shape, has fill ports on both sides (Right and Left side of truck), hieght is even with the PU sides, it is not as wide as the PU bed by about 6-8 inches, Has Supply, Return, Vent ports. It has a fuel level sender. It has a bottom port on the back side of the tank (drain or hookup to keep OEM tank full).
When I was running to Alaska all the time I ran the engine off the RDS tank and had a electric pump on my OEM 35 gallon tank and pumped the OEM to the RDS when the RDS got about 1/2 tank or so. It was really handy then so I could run the Alcan without buying fuel, saved a lot of money as fuel was always higher on the Alcan than we could buy it at Edmonton, AB or Tok, Alaska etc. .
I just in the last year unhooked the RDS and plumbed the OEM tank back to the engine as I am only driving the PU 3000 to 5000 mile per year now. The tank still resides in the bed of my PU where it has been for years. It will probably stay there until I sell it.
I just did a mod to my fuel level sender in the OEM tank to make it work and used the RDS to hold the fuel in the OEM tank while I dropped it to fix the sender.
I can send pics if ya want.
John
