Well I think I have solved the lift pump problem. Added a Carter P4601HP pump back by the fuel tank. At the rear of the motor on the lifting eye put a bracket & installed a filter housing from a Cat 3126 & a 2 micron filter. Plumbed in series. Plan to remove the factory L/P get rid of the banjo fittings & put in a fresh Carter pump & carry the used one for a spare.
