I ran across this interesting link about lighting, it pertains to California code but also has DOT information and a letter from DOT at the bottom.
Here are some highlights:
Whats your State say?
- Any motor vehicle may be equipped with not to exceed two auxiliary driving lamps mounted on the front at a height of not less than 16 inches nor more than 42 inches. Driving lamps are lamps designed for supplementing the upper beam from headlamps and may not be lighted with the lower beam.
- Driving, passing, and fog lights are all "auxiliary lighting equipment" within the definition of the Vehicle Code.
- Aux lights that are OEM equipped must meet DOT specs
- Aux lights you add do not have to meet DOT specs- including the wattage!
- Lamps above 42” are considered “Off Road Lamps” and must be covered.
