Heard somewhere along the way that the 03, HO 2500 6 speed has a pusher type fuel pump in the fuel tank. If that is the case I "Goofed" in hooking up my in the bed fuel tank by using the same plumbing as on my 98 Dodge w/cummins, using the provided 6 port selective switching valve. So how would I fix her right now in order to get the benefit of "lift" from the fuel pump instead of only gravity feed when switched to "AUX"?
