Awful noise in front end....
Dash trim swaps? hate the woodgrain...
Installing Subwoofer
... with my 2006 3500 ST 4x4, quad cab, LB, SRW. Less than 14K miles... still under warranty.
What I have is a persistent midrange to slightly high-pitched howling sound coming from the front end, when the vehicle is in gear. The noise seems particularly noticeable when stationary, starting into motion... . there is also a noticeable "crescendo" when turning the steering wheel in this situation, accompanied by a somewhat distressing "grinding" component in the noise.
Any insights, before I take her in to the dealership?
Many thanks,
Chris
If the problem gets worse as you turn... and you get what feels like wheel hop... . than my guess is a u-joint but this is very premature on your low mileage...
What I'm guessing is really the problem is a bearing out of one wheel and when you turn there is more side pressure on it... making more noise... .
Make sure you tell us what they found... .
