I have a 1997 Dodge 3/4 ton, 4X4 with the Cummins Diesel. I realize this question is specifically about the Power train, but I'm obsessed with removing both front axle nuts off my truck to have the rotors turned. I realize the rotors can be turned while on the vehicle, but thats too easy. I already tried all the true and tested remedies for removing these nuts. It should be noted the truck has the sealed bearings which are pressed together with the rotor. These babies are on there good. Any suggestions. I have been advised this is common problem for dodge trucks with this type of arrangement and I should take it to a good brake shop. Suggestions will be appreciated. Thanks, Ron
