Rosco said:The axle is identical. The only difference is in the springs and the drw may have bigger pistons in the rear calipers.
macdaddy said:Rosco
They are actually not identical. The Pistons are indeed larger along with the axel shafts are longer. Check out Readers rigs members name Greg Boardman in Twentynine palms Ca who did a DRW to SRW conversion on a 03 the photos clearly show it. No flame intended!!!![]()
Mac
JohnnyH said:The springs ARE different. A SRW has the identical springs as a 2500, but with the addition of overloads. I believe the SRW and 2500 have 4 Main springs with 2 overloads on the 3500. The DRW has only 3 Main springs with 2 overloads. I'm sure someone on here can go out and verify this or post some photos.
XJSuperman said:No they ARE not
I was under 2 duallies today... EXACT same spring pack as my SRW 3500. 3 long leaves with a short leaf on the bottom and the 2 overloads on top. 6 total leaves NOTc ounting the factory lift blocks (which were the same also) Which means NO difference between SRW and DRW other than dual rear wheels... and the ONLY other difference with the 2500 is there are no overloads.
Same axle, same springs, and some folks think the frames are different... UH-UH (i've had people try and tell me this). The dually gets it's extra towing and hauling capacity from being a DUALLY. Nothing else.
