Details here: TDR Privileges
Changing the axle fluid for the fist time at 15K. What do you recommend? Does Redline get any respect for AAM axles, or should I stick to the recommended stuff?
Has anyone had any problems using the thicker 85/140,I tow alittle bit(tt around 7500 lbs ) but I only do it maybe 10 times a year and was wondering if the thicker stuff in the winter would be to much for the rear. I will definitely use synthetic but something I was wondering about.
