TRAMPLINEMAN
Will a Dana 80 rear axle out of a ‘95 bolt right up to an ‘02 that has a Dana 80? Both have 3.55 gears.
Not mine, guy I know blew up his rear end and has access to a free 80 out of a ‘95. Was just wondering if it would bolt right up.A huge negative is going from disk to drums! Fix what you have IMHO.
I assumed it would too, but I can always cut off and weld the brackets where they need to be.I ASSUME it would bolt up but someone else with more knowledge hopefully will chime in.
Good question, I have no idea!Will the speedometer on the '02 work on the '95 axle?
Going from disc to drum also may be different line pressures? I know when I did that on my Chevelle, I had to swap the MC and the proportioning valve (front drum to disc) not sure if that applies here but something to consider.
