Engine/Transmission (1998.5 - 2002) B-D Van Aiken box ?
Looking at a BD VA box, can this box be stacked, if so what is the best combo and how do you go about stacking the boxes? How do injectors work with this box? This box is used so I dont know the details, going to look at later this week. Thanks for the help.
It plugs in using the big connector at the back of the VP44 injection pump. If by "stacking" you mean you are going to run it along with a fueling box like the TST PM3 or JVD Torque Enhancer, then you'll be pleased with the results. Don't stack it with an Edge Comp (use an Edge Pulse instead) or with an EZ Edge.
Works great with injectors. You'll need a bigger turbo to be able to USE the horsepower without excessive EGT's.
